Lift pump idea/question
Discussion in '1982-Present GM Diesel' started by jarheadk5, Mar 8, 2006.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I have a 6.2 from an '87 C10 that's getting swapped into my '87 K5 to replace the TBI 305. My K5 has the in-tank TBI pump, which is supposed to put out about 12-16psi. The 6.2 has what appears to be a mechanical lift pump on it (same place, same appearance as a gasser's mech. fuel pump).
    Anyone see any issues with leaving the TBI pump in the tank to feed the mechanical lift pump on the engine?
    I'm planning to leave the K5's stock fuel filter in place (in-line, in the pass. framerail) - any issues with this? I'm still gonna use the diesel-specific filter at the firewall (the rectangular-box-type from the donor truck) as well.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I don't know about the filter may be too restricting is the only concern I would have if any ( no knowledge on how retrictive it is) but the pump in tank is actually a good thing to have, a lot of guys are adding that to help with the fuel flow and help purging air from the system when they run out of fuel.
    :D
  3. maynardogle
    maynardogle 1/2 ton status
    Mar 7, 2005
    159
    Orange County, CA
    I don't think the pump in the tank will have a problem pumping diesel fuel...Having replaced a couple, I think putting the pump in the tank on any vehicle is asinine. But... you run what you got sometimes. If you leave the pump in the tank...you can bypass the mechanical pump.
  4. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    I would look into a 6.5 lift pump. It will mount to the frame rail using the existing lines from your Tbi. It puts out around 7psi. It is more convenient that the in tank with the advantages of electric.
    Good luck
