Lift Question concerning an m1008.....
Discussion in 'The Garage' started by uao85, Jun 4, 2006.
  1. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    I am looking to lift my m1008 pretty soon and had a few questions about pinion angle. I am looking to lift it about 6" and have a set of 36" humvee mtrs on the truck so nothing too radical. My first question, I have heard that when you install a shackle flip on a blazer its a perfect cure for the bad pinion angle caused by the lift, but on longer wheelbase vehicles like a lwb or a sub that it will point the pinion too far upward and cause a bad pinion angle. Is this true? If so what can I do to fix this? Also what will I need to do to the front pinion angle after its lifted, I know I will need a longer driveshaft, but am curious if this is all I will need. I am thinking 6" front spring, and a 4" shackle flip in the rear with a zero-rate as far as the lift goes, or if the pinion angle is too much in the rear, maybe a 2.5" shackle flip and a 4" spring lift??? What would you guys do if it was your truck and this was the lift combo you wanted on the truck. What rear suspension setup would I need to go with to take care of the pinion angle as effectively as possible?
    Regards,
    Remington
  2. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
  3. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    The rear should have a factory shim in it, you may just need to remove it after the flip is installed.
