Lift question
Discussion in 'The Garage' started by climbingmadman2000, Oct 12, 2004.
  1. climbingmadman2000
    climbingmadman2000 Registered Member
    Jul 20, 2004
    37
    Menlo Park, CA
    How hard is it to do a mild suspension lift yourself? Suppose I want to lift my K5 a couple inches to fit 33's. Can a backyard mechanic install the new springs, etc needed? Do I need to worry about changing axle ratios?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I suggest a helper or two . It is a pain to move the axles yourself . And safer with someone helping too . But it can be done yourself if you must .
    33's will need a new ratio , but if you are strapped for cash I know for a fact that 3.08's will work with 33's for a while .
    I am still driving mine on 3.08's with a 700 and a 305 motor /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i did my 1 ton swap shackle flip 6 in lift ETC... by my self so ya no problems!! /forums/images/graemlins/waytogo.gif
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    It can be done alone no problem, I did it to mine. But I have a garage and a few items which eased along the process. Your results may differ but on a '79 northeastern K5 (rotbox) I used many misc air tools, sawzall, and cutting torch as well as jack stands and 2 floor jacks. It can be done with a small craftsman tool set but be prepared for a lot of swearing if you have bad rust.
