Lift Question??
Discussion in 'The Garage' started by tbsdontstop, May 25, 2005.
  1. tbsdontstop
    tbsdontstop Registered Member
    Oct 31, 2004
    15
    Michigan
    I was wondering if I add one leaf to the front and rear for a 2" lift will I have to do any other modifications? It will be done to an 82 Blazer. I want a higher truck without having to do the driveshafts b/c I dont have the money but I have a leaf spring pack that I can strip for a lift. Also I figure since I am taking the rear off to add a leaf to fix one that is broke why not give the whole truck a little lift by adding an extra one to all 4 corners.
  2. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    you can do 2" without any other mods
  3. tbsdontstop
    Oct 31, 2004
    15
    Michigan
    thanks also my friend told me that I can jack up my truck and the suspension droop would be as much as I can lift it without doing my driveshafts is that a good way to do it?? Or should I do it like that with the axles unbolted from the springs?
  4. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    it depends on how much articulation you have, and how much drive shaft is left
