Lift question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by skyrocco16v, Aug 24, 2005.
  1. skyrocco16v
    skyrocco16v Registered Member
    Jan 17, 2004
    14
    ok, i'm sure that this has been asked many many times before, but, if i go up 6 in with my 86 k5, what kind of driveline issues am i going to run into?
    thanks
    corey
  2. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    4" will usually stretch, but at 6" you are really pushing it with stock length stuff. to have a driveline shop make yours longer is pretty cheap if the stock ones are i good shape.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Post this in the Garage and you will get many more responses. :waytogo:
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    My friend lifted his '84 and the front works fine. The rear shaft will still slide into the t-case and he drives it like that, but it really needs to be longer to be done right.
  5. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Had to do a little clearance grinding on the front,had a new one made for rear...
