Lift Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Anteak, Aug 9, 2001.
  1. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    On a lift kit, where is the lift measured from?
    Spring to the bump stop?
    I'm currently looking at a blazer that's for sale that claims a 4" lift installed by prior owners. Front spring has 2 leafs (stock set up?) but without the stock sag. Also running Rancho 9000s all around.
    And if it is lifted, how long do they normaly last?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im not 100% sure, but I believe the lift is measured by the amount of arch in the springs.
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I don't know about where the lift is measured from. I got a 4" lift from Rough Country and it raised my bumper height by about 6". But, tht is because of my sagging stock springs that were replaced.
    As far as stock setup goes, tis was on a post earlier today, but stock front springs and lifted front springs are easy to tell apart. Stock front springs arch upwards, i.e. they resemble an upside down U; lifted front springs arch downwards, i.e. like a U.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    PM me for a great deal on blinker fluid! Best price on the net!
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    here is a post a while back where everybody listed what kind of list they had, etc. and they measured from the top of the axle to the bump stop bracket. you might wanna search for it and check it out.
    <font color=blue> Jeff - may the force be with you</font color=blue>
  5. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    Having compared multiple size lift springs side by side I've found that the springs are simply taller in height by whatever ammount of lift designated. This being accomplished by adding leaves, thickening the leaves, or increasing the arch of the spring. If you set stock springs on their eyes so that the high point of the arch is up in the air and then do the same with a set of x" lift springs then you'll see that the bottom of the spring pack on the lift springs is x" taller than the bottom of the stock spring pack.
    Hope that made sense,
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
