Lift Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer_87, Nov 2, 2001.
  1. blazer_87
    blazer_87 Registered Member
    Oct 1, 2001
    72
    Section, Alabama
    Can I put 35's under 2 1/2" suspension lift on my 87? How much cutting will I have to do? Will I be able to do any good wheelin with that setup? I am looking for the biggest tire/lowest lift combo and still be able to crawl and mud some. Thanks for any info
    87 Blazer 32x11.50s
    2B1ASK1
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you can put any size tire on if you are willing to part with enuff sheetmetal. I would run 44" with a 4" lift and put the sheetmetal on a massive diet.
    Bob the rear, totally cut out the front and (like posts have shown here) and trim the flare in the front of the rear wheel well. should give the clearence.
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    You will definetly be trimming! Alot of guys have a 4" setup and it will rub a bit. It also depends howmuch you are flex'n.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would definitely recommend against it. I've got a 4" lift and 35s. It ain't cool if your tires rub. Get at least a 4".
    Tim
