lift question
Discussion in 'The Garage' started by nicotine, Jan 15, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    i am going to be installing a 4inch front and i need to know should i go hd or ez ride i will be putting a bumber on that my guess will weight at least 150lb with winch if not more should i go with hd or ez ride?
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Buy a bit taller EZ ride spring and let it settle
    Or buy the softer riding spring, and if it settles, put a zero rate ord whatchamathinger under the springs
    What brand are you buying? Tough Country seems to be the fan fave and is what I have, but haven't ridden on yet
  3. nicotine
    Jan 11, 2004
    116
    i want the 4 inch tough country ez ride but i am not sure how much they settle?
  4. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I installed Tuff Country 4" EZ rides in July 02, got 5 1/4" of lift over my worn springs. Been very happy with the ride and hasnt settled much either. Buy new greasable shackles from ORD while youre at it. If it sags too much install 1" Zero rate block from ORD. good luck /forums/images/graemlins/thumb.gif
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I had a tough country 4" in my old 76. Only sagged 1/2" in front (blocks in rear) I ended up putting longer, greasable shackle's in front and had 5" over stock.
  6. nicotine
    Jan 11, 2004
    116
    how long in inches in the typical front shock for a 4 inch lift?
  7. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    How much will you be flexing it? Will you be using your swaybar? I ran 4" E-Z rides for a couple years with no loss in height. Then, I removed the swaybar for more serious off-roading and I quickly lost 1.5 inches. I now wish I had 6" E-Z rides. I would second the idea of 6" E-Z rides and let them settle.
  8. nicotine
    Jan 11, 2004
    116
    but what is the length of a shock need for the front with 4 inch ezride and 33 inch tires? will 23.5 inch shocks work?
  9. DougK20
    Feb 18, 2003
    384
    Boise, ID
    I only know one length = Use Ford towers and go as long as you can. /forums/images/graemlins/smirk.gif
  10. nicotine
    Jan 11, 2004
    116
    still didnt awnser my question about the 23.5 inch shocks in the front with 4 inch ez rides?
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Way too short with the Ford towers. Mine are going to be 30" long. /forums/images/graemlins/thumb.gif
  12. nicotine
    Jan 11, 2004
    116
    w/o ford towers it is a dana 44 up front with stock shock mounts.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Measure it.
    I wish I'd never wasted my money on cheesy stock mounts though. Could have had the Gabrials I got from AZ (G63468) and Ford towers for less total money expended!
  14. nicotine
    Jan 11, 2004
    116
    i dont have the 4 inch springs in yet just oredered them and i am trying to figure all the little details out. the guy at shwabs said thos shocks should be long enough but i dont know if i trust those guys even though this guy has a crew cab chevy with 38's he should know what he is talking about but i just dont know. input on this would greatly be appreciated. thanx /forums/images/graemlins/1zhelp.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you take nothing from this post, take this:
    FORD TOWERS ($30)
    Gabriel shocks, G63438, 30" long, 12" travel ($20 each)
    Total = $70 vs. $50 plus shipping for the other guy's shocks that are too short, use stock mounts, and suck ass anyway and don't have a lifetime warranty.
    Definitely the poor man's long travel arrangement.
  16. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    My 4" shocks measure 12.5" from the center of the bottom bolt to the weld on the top of the body. Usually the reccomended length will work for moderate use. If you pull the sway bar and flex a lot the shocks will become limiting tubes (for both compression and extension; ask me how I know /forums/images/graemlins/wink.gif).
    84_chevy_k10 what are the longest length on those gabriels you mentioned?
  17. nicotine
    Jan 11, 2004
    116
    i didnt realize the ford towers were 30 bucks who sells them?
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Try the Ford dealer. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They're ABOUT 30". I think the book says 29.73 IIRC.
    12.53" travel too, which puts them at 17.47 compressed if my cheesy math is correct.
    All I know is that they're the longest ones I can find in the book that still mount in a useful way.
    Now if they can be mounted upside down or not stands to be seen.
  20. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Ford sells an entire shock mounting bracket for $30, chevy sells the the shock bolts for $28 (sarcastic pricing).
