lift questions for blazer
Discussion in '1992-Present Chevy & GMC models' started by hoppy, Mar 21, 2003.
  1. hoppy
    hoppy Registered Member
    Aug 20, 2002
    56
    thinking about putting a suspension kit and tires and rims on the blazer(94) was thinking 3" lift with 32's......i just think 6" is to much or isnt it? will the 32's fit with the 3" lift? what other mods will i have to do besides just putting the kit in? any cutting? welding? any feedback would be helpfull. what are the better kits out there? can you mix and match parts.....say procomp lift with bilstein shocks or such?
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    If you are only gonna run 32s, shouldn't need a lift. The 265s are a little over 32" tall, just not the same width. You can put 33s on a 3" lift. I yanked all my IFS garbage out an put a real front end it, a Dana 60!! /forums/images/graemlins/grin.gif As far as cutting or welding, I honestly don't know, never done one.
  3. Miller
    Miller Registered Member
    Mar 21, 2003
    56
    Mtn Home Idaho
    you can mix and match difrent shocks to difrent kits, but you cant mix any kit components up like the drop brackets, cross members n such.
    no on alot of kits not there is very little if any cutting and welding, with 6" kit the crossover pipe on the exhaust may have to be rerouted to clear the front driveshaft.
    if you went with a kit desinged like the rcd then that is basicaly straight bolt on kit. wich means the truck can be takn back to stock.
    the 265s will fit with no lift at all. and if theyre measuering 32"s then thats taller 265. 285s measuer 32.5.
    no lift needed for the 265x75x16 tire
  4. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    265s = 31.6"
    285s = 32.8"
    you don't need a lift to fit them if you are using stock wheels.
    if you go 16x8s, then 265s will fit, 285s will rub and you'll need a lift and/or trimming.
