Lift questions
Discussion in 'The Garage' started by skelly1, Feb 21, 2005.
  1. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Currently my 1990 has 4" springs all the way around. I would like to get a little more lift out of it when I get my 36" Iroks and have it sit about level. That said, I figure on using a zero rate in the front and a 2.5" shackle flip in the rear. Is it OK to use the flip with lift springs? Will this thing sit level or stinkbug?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Stinkbug, unless the butt is sagging already, a common problem. Just put zero rates front and rear. Less work and it will sit exactly how it does now, but one inch taller.
  3. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    where do you get these 1" zero rate springs?
  4. shanemcg45
    shanemcg45 Registered Member
    Feb 7, 2005
    78
    Lubbock, TX
