Lift questions
Discussion in 'The Garage' started by nad, Apr 3, 2006.
  1. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    I'm a newbie still, and just lifted my truck 4". I kind of want it a bit bigger still, but I am worried about having to extend the drive shafts. Is it possible and safe to lift it 6" without having to extend driveshafts?? I know brake lines will need to be extended, but that's not that big of a deal. Also, would I need to extend my steering arm or pitman arm at all???
    Also, doesn't ORD make some kind of shackle that I can add that 2" of extra lift with, instead of actually buying a totally new lift?
    Any information/suggestions would be appreciated. Thanks very much.
    Dan
  2. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    I ran a 6" BDS lift with stock driveshafts. It worked fine, I could still flex it all the way out (as much as a 6" spring will flex) with no problems. But i was going through rear u joints like every 2 months or so. For brake lines I just got like stock 1992 chevy 3500 front lines, and moved the rear.
  3. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    more than 4" usually means driveline modification. brake lines, shocks, everything will need to be changed. ORD makes a kit to flip the shackle and you can get it in 2.5" and 4" lift, DIY4x also makes the 4" kit, but better. you could also throw a zero rate in the front and get a little more there. but going to 6" will also require a few pieces to be changed in the steering.
    and dont forget about body lift. most dont like them including myself, but you can run a 4" sus lift and 3" body lift and be ok on drivelines and things. and you will have that 7" look.
  4. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    I don't like the looks of body lifts. Plus, when you do them, don't you have to extend the throttle cable, and a whole bunch of other crap?
    So if I use the shackle flips, would I have to extend drive shafts? If I put a zero rate in the front, it would sit higher than the back wouldn't it? What would have to be changed in the steering? Just a drop down steering arm?
    Dan
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i ran a 6 inch all spring on my 88 for 3 or 4 years and only had to shim down the transfer case with the supplied spacers and had no problems whatsoever.
    you can do it easily with no worries
  6. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    solid axle? are you talking about clocking a 241?.
    what ever you do, if you havent done anything to your steering yet, you will have to. but a lot of "drop pitman arms" and thing like that are designed to work with both 4" and 6" lifts. body lifts usually require things like steering shaft modification, breaklines, extended wiring harnesses, etc. but it is an option. you can throw the 2.5 shackle flip in the rear, and a zero rate in the front. this will give you a bit more lift in the rear, but that is more like the factory look anyways.
    things to think about when adding to your current lift: pinion angle, driveshaft length, longer brakelines, shocks, etc. you might need to shim your axles to get the proper pinion angle once you lift it more, and you might need longer driveshafts. people have varied results. you will probably need longer shocks with more travel, and longer breaklines.
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    He is talking about moving the spacers that come stock on the tcase crossmember to the top of the crossmember.
  8. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    ok, didnt know about those. im more familiar with older stuff.
  9. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    why are you afraid to lengthen the driveshafts ? its not that exspensive
  10. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    leper has it right. the spacers are, from the factory, above the frame and if you move them below the frame between the crossmember and the frame it will lower your t-case down an inch or so.
    i used a 6" steering arm in conjunction with the lift as well and had no problems with it. no driveline vibrations, no steering issues nothing.
    go over 6" and you will have some more issues to deal with: brakelines, more steering issues, and front driveshaft issues.
