lift question's
Discussion in 'The Garage' started by 85 Jimmy, Jan 8, 2007.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    ok, i know this has been covered but this is my plan for my lift. i'd like to know what you guys think i should do if this isn't good enough. i'm not an expert like most of you guys so let me know
    i want a total of 6 or 7 inches of lift
    my plan for the rear was a shackle flip from DIY and some 2" lift springs
    for the front i was going to get some 6" springs
    i know i'll need some knew shocks but not sure which ones (this is were i need ya'lls help) i also know that i'll need some extended brake lines. is there anything else? i already have a 6" raised steering arm, and i know i MIGHT need to lengthen my shaft.
    keep in mind this is my DD but in the future it'll be my full time trail rig, so ride quality doesn't matter. i also would like to have alot of flex. but i don't want to put 52's or 56's up front, i'm no good at welding (yet)
    so what do you guy's think? what else would i need or what should i change?
  2. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    if you wanna save some money...buy a set of 4 inch springs then 2 sets of zero rates one front one rear..with the shacle flip you will get 5 inches...use the sawzall for the rest...what tire you running???
  3. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    right now i'm only running a 35" but when i go full trail rig i'd like to be running 38"-40"
  4. twoslo4five0
    Oct 5, 2006
    6,615
    71
    i would do the 5 inches..look in the classifides for some 4inch springs...as far as shocks i just run some bds shocks there like 15 20 bucks each...and go ahaead and get brake lines..about 100...my lif was all brand new from bds and was like 600 bucks...with brake lines..
