lift questions
Discussion in 'The Garage' started by bear, Oct 9, 2002.
  1. bear
    bear Registered Member
    Sep 16, 2002
    31
    Georgia
    Ive talked with the local 4x4 shop about lifting my 83 K5 on a budget of around $400. They recommended getting 2.5 inch lift blocks in the rear and 2.5 inch lift springs in the front. Are any of you guys running this setup or something similar? I want to lift the Blazer so I can run 33" tires. What other costs should i worry about (extended brake lines, new shocks, etc......) any advice or pictures greatly appreciated. thanks.
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    33x12.5 should be find with a 2 1/2" lift, but you may need to do some minnor triming on the front fender. First are you going to install it or are they? For $400 you should get shocks with the lift if you installing it. What brand are they selling you. You shouldn't have to extend the brake lines, no need to change the steering arm. I would recommend that you change the u-joints out though, due to they end up vibrating after you lift the vehical depending on how old they are.
  3. bear
    Sep 16, 2002
    31
    Georgia
    yeah, the $400 includes installation......I just bought new shocks, heavy duty Monroes so I didnt think that would be a problem. How bad is the vibration with the u-joints?
