Lift Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cryptobiotic, Apr 17, 2003.
  1. cryptobiotic
    cryptobiotic Registered Member
    Dec 31, 2002
    53
    Utah
    I am running a 4 inch Rancho lift right now that is probably about 10 yrs old and definitly needs replacing, I was thinking of getting a 6' skyjacker lift with racho 9000 shocks, I don't wheel too much it's mainly for show and to be higher than all those fords all over the place, I am just wondering how much extra work will have to go into this? or is it even worth it? Should I just stay 4'? please let me know your opinions!! /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    If hieght is what you want, and you are going to replace the lift anyway... might as well lift it higher right? If you dont plan on using the thing off road much... then Id recommend just getting a 6" kit from rancho, procomp or whoever else is a reputable manufacturer and on sale (if cost is even an issue!). Blocks are an ok way to lift the rear end of your rig if you dont wheel your rig. Springs in the 500 lbs/in range will make sure you can corner ok on-road. The kit should come with a drop pitman arm or something to keep your steering geometry a-ok... and with a 6" lift you may need to get your rear driveshaft lengthened.
    j
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Is ride quality importent to you ??? If not, then Rough country would be okay, but if you don't want that lumber wagon ride, look into BDS or Tuff Country.
  4. straightBOGGINnMY74
    straightBOGGINnMY74 Registered Member
    Apr 17, 2003
    6
    AUBURN,AL
    thats not gonna be cheap...if money is an issue
  5. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    going to a 6inch will cost more than you with all the steering stuff extended brake lines and getting a longer drive shaft. Stay away from pro comp and rancho way to stiff of springs, skyjacker rides really good and from what I heard BDS is the best
  6. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Mine is riding like a Cadillac with the sway bar off...I have the Skyjacker soft ride lift. I'd just stay with the 4" since you already know it works with your setup. Skyjacker lift kits are a little taller than stated, mine was really 5.25".
