Lift Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Dec 5, 2000.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    ---(SHORTENED)---
    Well, I think I am going to lift my k5 over Christmas break, but I have some questions:
    1. I am going to put 4" blocks in the rear, my main question is what should I do with the front? I want to springs, but what size??? What about shackles??? I have a stock 88 w/ 10 bolts, and I don't want "saggy butt".
    2. I am buying some used 3 yr. old 4" Rancho blocks from someone w/ a k5, that person has a 75, will I be ok putting the blocks on my stock 88 w/ 10 bolts?
    3. Anything else I should buy? My list is as follows:
    lift blocks for the rear
    rear U bolts
    4 rancho 9000s
    TC front springs
    steering arm
  2. EODBRIAN
    EODBRIAN Registered Member
    Feb 19, 2000
    82
    Indiana
    Re: What to do??? (lift)
    man, thats a lot of questions. i would give stephen at ord a call (970-945-7777) and explain your situation. ive dealt with him as im sure many others on the board have. VERY straight shooter as to your needs with no sales hype or b.s. hope all goes well. take care.
    EODBRIAN
  3. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Ok, someone has to be able to help me, its CK5! You guys know everything!
    Dawson
    88 K5
  4. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    I'll help. Ok, if you put 4 inch blocks in the rear shouldn't you get 4 inch springs in the front? WHAT ABOUT shackles??? How much are you paying for the used blocks? I think you should get new ones since they only cost about 20-30 $$. If you plan to flex the k5 you should get longer brake lines. That's about all you need added to the list. Remembere when you put the blocks in make sure that they are facing the right way. Good luck and I wanna see some pics after you are done. I thaught you were going with a shackle flip in the rear? $$ problems?
    [​IMG]K5[​IMG]
