lift questions?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by aj_tatted, Sep 19, 2003.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    hey guys, i started putting on my lift today and relized how far the drive line was extending. was is a exceptible length for it to be pulled out? also when pivoting my tranny what is the best possible way of doing that? i thought of putting spacers between the crossover brace and the frame but i'm not sure if this is how it's done. /forums/images/graemlins/thinking.gif /forums/images/graemlins/eek.gif
  2. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    First I need to know how much lift your installing...generally lowering the drive train or pivoting the tranny is not needed....also if you pivot the tranny you put stress on the engine mounts....
  3. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    the lift i put on was a 6" procomp suspension.i put 1" spacers between the frame and the cross brace under the transfer case because the angle looked to be to extreme. i'm getting alittle shimmy in low rpms from somewhere underneathnot sure what i tcould be.i appreciate any input you can offer.thnx aj /forums/images/graemlins/ears.gif
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    When i went from a 4" to a ~6" lift my driveshafts ended up too short and i got new ones built. /forums/images/graemlins/tongue.gif
    I also just looked at your profile and this is for your '84?
    Ya posted in the first gen '69-'72 forum... you might have better help in the second gen '73-'91 forum. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  5. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    you need to check to see that all yokes are on the same plane. this is most likly where you shimmy is comming from and you rear shaft yokes are most likly the culpret since you probably don't have it in 4wd going down the highway.
