lift questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aj_tatted, Sep 19, 2003.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    hey guys, i started putting on my lift today and relized how far the drive line was extending. was is a exceptible length for it to be pulled out? also when pivoting my tranny what is the best possible way of doing that? i thought of putting spacers between the crossover brace and the frame but i'm not sure if this is how it's done.
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/rolleyes.gif
  2. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    the length im speaking of is out of the transfer case, currently it looks to be pulled out about 4" is this o.k?
    /forums/images/graemlins/1zhelp.gif
  3. La Barge
    La Barge Registered Member
    Jan 22, 2003
    68
    Gilbert , AZ
    is that measurement with the suspension dropped or on the ground. typically with 6" or more you will need a driveshaft spacer witch are sold aftermarket. the t-case spacers should go between the crossmember and the frame if needed. /forums/images/graemlins/thumb.gif
  4. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    whrer would i find a driveshaft spacer and what do they look like? /forums/images/graemlins/confused.gif
  5. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    wait... you have a np205 and the shaft is pulling out of the tcase? /forums/images/graemlins/confused.gif is this one of them 1980 gm np205s with the slip yoke?!
    j
  6. La Barge
    Jan 22, 2003
    68
    Gilbert , AZ
    I'm talking about the front driveline the spacers can be found at any 4x4 shop. If you are talking about your rear driveline you will have to get it extended by a drivesaft place. possibly a cv installed as well.
  7. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    dunno , i know it has a slip yoke though because it slides back and forth on the spline. i drove it today and it will drive however there's a little shimmy in low rpm's. i have pics of what i'm talking about but i have the damnest time getting them on here.also how far should i drop the transfer case? i shimmed it 1" on the cross over beam and it seemed reasonable. i hope i'm not tearing up u-joints. one thing after another. my seal seems to be leaking alittle now([darn]) /forums/images/graemlins/angryfire.gif guess i'll have to replace that next. i appreciate all the input i can get as i'm doing this on my own in order to be at one with my truck(lol)thnx guys /forums/images/graemlins/thumb.gif
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I think 1" is about max you wanna go for dropping your trans/tcase down. More than that and your distributor gets awfully close or contacts the firewall and you don't want that. The slip yoke should be about halfway in the tcase sitting in your driveway. You really should pull it and measure then reinstall and find out where you are at. 4" lift and you could probably get by with the rear shaft for street driving. MAYBE> 6" lift will need driveshaft lengthening. Have fun.
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    when you say "it" are you refering to the tcase or the driveshaft?
    j
