lift qustion
Discussion in 'The Garage' started by meangreen, Apr 27, 2004.
  1. meangreen
    meangreen Registered Member
    Apr 27, 2004
    6
    I am looking at a buying 91 k5 and I want to know if there is any complete lift kits out there for them that lifts it 6inches or more that come with ALL the leaf springs and not just blocks for the rear, thanks, meangreen
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    There are a lot of companies that make lift kits for your truck that come with both new front and back springs instead of blocks in the rear. Take your pick Rancho, Skyjacker, Tough Country, Rough Country...the list goes on and on. It will cost you about $300 more than a lift kit with blocks, but it is a better way to go.
    I am thinking of ripping out the crummy 3-inch Rancho suspension lift (springs in the front and blocks in the rear) that came with my truck when I bought it. I want to replace it with a 4-inch shackle flip and greasable bushings kit from ORD, custom made rear OEM springs from Alcan, and custom made 4-inch lift front springs, also from Alcan.
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I recommend BDS or tuff country for springs /forums/images/graemlins/thumb.gif
  4. meangreen
    Apr 27, 2004
    6
    I have heen looking at the procomps becuse I like the ones on my cjand I want to do 8in of lift total, I want to swap in a 14 bolt rear end and something bigger in the front(any suggestions)and run 38-40 inch tires, I chosse a k5 for the price(found one for 600 with out to many problems) and my cj7 dosent have the room for my family to take the trips with me(especally with paragon only 3 hours away) just looking for a lift it and forget it type swap(little to no brakeage) /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gifany suggestions?
  5. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    BDS 8"
    BDS has a break it we replace it policy hard to beat man...
    and they are smooth and pretty flexy.
