lift requirements
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Blazer-Boy, Jun 3, 2002.
  1. Blazer-Boy
    Blazer-Boy Registered Member
    Jan 29, 2002
    25
    Eagle River, Alaska
    is there anywhere that there is information on how big of tires you can get with body and suspension lifts? (new and old chevy's)
  2. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
  3. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    4wheelparts.com has a chart but it isn't exactly ricght
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    lift,i dont need no stinkin lift.hahaha.you can fit any size tire with a sawzall.just joking.id never cut my blzer body.id try to stay away from body lifts also.a lower center of gravity is a desirable thing.suspension lift is much safer.when you do body lift it sometimes requires more mods depending on how much you put in.throws off some stuff. id say check the forums and maybe www.4wheeloffroad.com might have more info
  5. Scorpion
    Scorpion Registered Member
    Jun 5, 2002
    60
    Denver, Colorado
    Take the 4x4 stores advice with a grain of salt. They claimed that I could fit 38's with a 6" lift on my Blazer and there is absolutely no way. I only ended up with less than a pinky's worth and 35's.
    The best advice I can give is get the lift you want to have and then try to do some test fittings. It's probably the most accurate since no rig is the same after a lift - a truck with some type of block in the back since you may be using an old set of set of springs under it..
