Lift Set Up Q's
Discussion in 'The Garage' started by big jimmy 91, May 15, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Lift Set Up Q\'s
    I have a 91 Jimmy running 35X14,s (stock , no lift)
    I have in my yard a set of 54" leafs from a 85 chev 1/2 ton (I thuoght they were 52,s /forums/images/graemlins/blush.gif)
    Now my question is can I use the 54" springs on the rear and put the 52" springs up front without moving the rear spring hanger (I am going to do the home made shackel flip by cutting the stock hanger and flipping the shackel over)
    I don't know if this will give me a bad shackel angle or cause other problems that I don't know about?
    I have very limited funds for a lift right now so I am just looking to lift it as cheap as possible to clear the 35's with mild trimming (the /forums/images/graemlins/hack.gif does not scare me as this is not a show truck)
    So if anyone can steer me in the right direction I would really appreciate it
    BTW , I did search and found a lot of good info but nothing on the 54,s
    Now I'm off to the mud hole for a little fun /forums/images/graemlins/whistling.gif
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Re: Lift Set Up Q\'s
    I think you may be talking about 56's, not 54's. You may have measured wrong, otherwise I am wrong because I am pretty sure chevy only made, 49's, 52's, 56's, and 63's /forums/images/graemlins/dunno.gif
  3. big jimmy 91
    Feb 21, 2004
    639
    I am not sure but when i pulled a tape on the ones in the truck they were 52" , and when I did it on the loose ones it was 53 1/2 " /forums/images/graemlins/confused.gif
    I just went strait across from eye to eye , I am not sure if that is the right way to measure them though lol.
    So are the loose springs just flatter or are there 54" springs on chevy trucks
    I wanted to start this project soon but don't know about these springs now???
    Any input on this would be a big help
    /forums/images/graemlins/ears.gif
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    they must be 56s, the numbers 52, 56, 63, etc are measured with the weight on the springs sitting there. measuring the ones on your rig will net 52" cause thats how they are to be measured. If you install those springs and measure they will be 56.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I knew it /forums/images/graemlins/smirk.gif
  6. big jimmy 91
    Feb 21, 2004
    639
    So I guess I will have to move the rear spring hangar back then to use them ?
    If so is it 4" ?
    Does this also move my rear end back 2" ?
    Will a longer DS be needed ?
    Sorry for all the Q's but I want to be sure before I start this lift
    BTW , I just looked into picking up a set of 36X12.5 " super swampers so lifting may become a rush very soon /forums/images/graemlins/whistling.gif
  7. big jimmy 91
    Feb 21, 2004
    639
    OK here's what I want to do...
    Put my 52" springs from the back to the front...
    Put the 56" springs I have in the rear with the home made shackel flip ( move the rear hanger back and cut it to flip the shackel)
    Can someone give me a brief start to finish of what needs to be done (ie. drive shaft lengths , shocks , steering etc.)
    I have searched through a lot of previous posts and there seems to be a few different ways of doing this.
    The best way of doing this is what I am after
    Thanks for any input /forums/images/graemlins/thumb.gif
  8. big jimmy 91
    Feb 21, 2004
    639
    Any Thoughts? /forums/images/graemlins/1zhelp.gif
  9. big jimmy 91
    Feb 21, 2004
    639
    TTT
    /forums/images/graemlins/thinking.gif
  10. big jimmy 91
    Feb 21, 2004
    639
    Just looking for some info. /forums/images/graemlins/1zhelp.gif
  11. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Just take the money for the 36" Swampers and find you a cheap lift kit for a few hundred bucks. There out there. I just got rid of my 4" and fit 35's fine with the 4 with not that bad of a rub.
