lift spring help...#check...got the numbers now...
Discussion in 'The Garage' started by broncoman6524, Jan 19, 2007.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    i've got some used springs that i need to get rebent i believe they are 6' lift...if anybodys got the numbers on top of there springs could you post it so i can try and confirm the lift height of them? thanks alot
    these are off the rear springs but there are two...first 13411 second10480. id greatly appreciate letting me know whrether this is a 6 or 4 inch kit
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you have springs that need to be re-arched they actually need to be replaced. At any rate, it would be easier for you to post what the spring number is on your springs then someone here can help you identify them.
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    A quick search yielded that they are pro comp springs and are a 6" rear spring.
