Lift Springs or ORDs 4" Shakle Flip?
Discussion in 'The Garage' started by Saxwonder84, Jul 7, 2004.
  1. Saxwonder84
    Saxwonder84 1/2 ton status
    Jun 27, 2002
    117
    Rockwall, Texas
    Lift Springs or ORDs 4\" Shakle Flip?
    So which is better? It is finally time to lift the thing so just wanting best bang for the buck. Thanks
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: Lift Springs or ORDs 4\" Shakle Flip?
    ORD Shackle Flip. /forums/images/graemlins/waytogo.gif
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    2 thumbs up for ORD's shackle flip /forums/images/graemlins/peace.gif
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Lift springs
    FYI shakle flip and towing is not reccomended.
    /forums/images/graemlins/ears.gif
  6. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    It really depends on what you want. Both have pro's and con's, I was planning on a shackle flip but I have decided on going with lift springs instead.
  7. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    do both! 4" springs, 4" shackle flip and a 2" block! best of everything! and i have almost stock driveline angle!
  8. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Not recommended by who? You? /forums/images/graemlins/rolleyes.gif
  9. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    It kind of depends on what you want, the shackle flip will give more flex. I have 6" lifted springs on mine because if I used a shackle flip it would mess my driveshaft angle up and I would have to buy a $300 CV shaft.
  10. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Or rotate your pinion back down /forums/images/graemlins/rolleyes.gif
    A shackle flip is fine for towing as long as you realize that it makes your suspension feel a little softer than before. You realy shoulden't be towing with a 1400RTI, high lifted, big tired tow rig....its just common sence. But if you want to lift your 3/4 ton a bit with a shackle lift you will be fine.
    This has been beat to death and the experts (ORD) say it is fine as long as you are smart about it. /forums/images/graemlins/thumb.gif
    EDIT: oh and I got the ORD flip a long time ago. I still use the brackets (moved to a new location) with my newer longer/softer All Pro springs. They are a quality product, and a good design that I would use again.
  11. Executioner
    Feb 22, 2000
    1,530
    Jup, I just made it up today. /forums/images/graemlins/screwy.gif
