Lift Springs???
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by raptorGTA, Jul 11, 2002.
  1. raptorGTA
    raptorGTA Registered Member
    Aug 21, 2001
    16
    I want to put a 6" on my 72. What springs are the best for ride comfort on the road? I was thinking about getting the BDS lift becouse I have heard good things about them.
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I hear a lot of good stuff about SkyJacker's Soft Ride springs and also about SuperLift's setups. A friend has a 4"/6" SkyJacker lift and likes it but his shocks are too soft on compression for those really soft springs.
  3. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    I have had a 6 inch skyjacker lift for about 4 years now and it still rides great.
  4. BAD4WD
    BAD4WD Registered Member
    Feb 4, 2002
    63
    Sonora
    I got sky.6" springs frt.& back with no conplants. But the best thing you can do is to install a sway bar from a '73 up 4x4. Made a big diff. going down the road.....
  5. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Asking someone's opinion about soft springs is like asking us what a pretty girl looks like..... /forums/images/icons/grin.gif
    Everyone has their own idea of "soft". I've ridden in a later model K5 with SuperLift springs and thought it was relatively stiff but acceptable. I had Rough Country springs in my '72 K5 and thought they SUCKED! They were WAY too stiff (over 700Lb/in rate) and made the truck miserable to drive.
    I have since added a custom set up front from ORD (about $400) which are down in the 240Lb/in range. NICE!!! I've had passengers ride in my K5 who also own Blazers and they use the word "Cadillac" to describe the ride. Of course a SUPER-SOFT spring like that will flex well too.
    The only downside so far with the soft springs is that it aggravated bumpsteer in a BIG way. I've had to buy a crossover steering setup to address that issue, and I think I'm gonna be a happy camper!!!
    My advice is to take a few rides with other K5 owners in your area (we're everywhere!) and get a feel for what YOU consider to be a comfortable ride.....then you'll know what brand of spring is right for you. /forums/images/icons/cool.gif
    Something else to consider which makes a BIG difference is tire pressure. When I first got my Blazer, I pumped my 35 x 12.50's up to 35 psi and with those stiff springs I thought my kidneys were gonna burst! Big tires don't need as much air pressure, because they aren't really carrying much "load"....I'm down to around 22 psi on the street now, and that helps a great deal. Even with soft springs, too much tire pressure will cause the "buckboard" feeling over bumps.
    By the way, fill out your profile a little bit more. If I know that you live close by, I'll offer you a ride in my '72 to check out the springs.
