Lift/Tire combo
Discussion in 'The Garage' started by 86haubs, Jan 3, 2006.
  1. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    I just need to know if I run 6" lift will 37x12.50's fit w/o rubbing? I would rather not cut my truck. Would it be better to got 4" and 35's? I will not be doing much wheeling, just some mud every now and then. I have a d60 and 14bsf, 4.10's and no lockers. What other mods will I have to do for 6" lift, is making the driveshafts longer neccesary?
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I have a 4 inch lift with 35's and had to cut. You will need longer drive-lines, and break lines.
  3. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    For 4" or for 6"?
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Some of it depends on the particular truck and the wheel offset. My Burb does great with 35's and 4-5 inches of lift. It "self clearenced" a bit, but not bad. I would definately have to cut to go to 37's
  5. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    you will want 6 inch break lines
  6. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    You really think I would have to trim to run 37's with 6"? If so maybe I should just run 35's.
  7. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    you obviously aren't worried about offroad performance...just get either 4"/35s or 6"/37s and run the stiffest springs you can buy (I'd recommend Rancho HDs). Even without an anti-sway bay, you won't have any flex, rub, or need to trim then. They will work great for your mall crawler. Drivelines will be fine, take 'em to a local shop and have them lengthened. It ain't to spendy. You will need longer brake lines (search for the part store #...) and probably shocks too (again, part store #, get some gabriels, they are cheap).
    j
  8. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i think you would be ok with 6 with 37 's . i have 6'' on mine and i ran 38's on my blazer i did trim some because if i hit a rut really hard it would rub so i think you would be good with those .
