Lift/Tire opinion's wanted. (not a will it fit post)
Discussion in 'The Garage' started by BamBamblazer, Feb 10, 2004.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    Lift/Tire opinion\'s wanted. (not a will it fit post)
    Like i said this is not a will it fit post as i have a sawz-all and im not afraid to use it. Well not too afraid anyways. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Right now i have 6" superlifts up front and blocks in the rear. I want to go with a homemade echobit style flip for the rear to get rid of the blocks. The front will probobly stay as is for now. I have 35x12.50's right now but i really want bigger. I'm still on 10 bolts but that is gunna change before i do anything else. So i guess what i am asking is should i stay with 35's or should i go to 38's or 40's and start cuttin. I need to get new wheels also as i am going 8 lug so do i stay with 15" or do i go 16.5" I know this is opening up a can of worms but i just want opinions on what you would do. The k5 will be street driven and i want it to be able to wheel with the best of them if you know what i mean. No extream wheeling, but i want it to be able to if i decide too.
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Re: Lift/Tire opinion\'s wanted. (not a will it fit post)
    I would try to get a another 2" or so out of your 6" lift and get a 3" body lift along with a little cutting probably.
    Might as well go 40's if you are considering them because soon as you play with 38's, you will wan't bigger ones.(kind of like breasts, someones sig /forums/images/graemlins/rotfl.gif)
    I am not afraid of 16.5's myself but if you plan on airing down a lot then a 15 or 16" wheel might be a better choice.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    echobit with a 6" shackle and 57" springs should net 6" of lift (add a 2" lift spring for 8"). Trim the bottom ears off the back fenders, and start trimming in the front... 1-2" body lift and some good springs up front... 15" rims and 37-38" tires 5.13's... OH WAIT, thats the setup I'm shooting for /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/woot.gif
  4. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Stay at 6" and cut till you can put 40's on. Try to run 16" rims if your gonna move up to 1 ton stuff so you dont have to grind any. I plan on running 40's on 6 inches someday.
    Nick
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I say brake out the sawzall and make some 40's fit. Here is a pick of my k5. Front is 4" rough county springs with 1" zero rate axle moved 1.5" forward.
    Rear is stock springs 1" zero rate echobit shackle flip
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Go 40's. /forums/images/graemlins/waytogo.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Stick with 35s or 36s unless you get 1 ton gear. No sense in having $1200 worth of tires without the drivetrain to support it.
