Lift / tire size question
Discussion in 'The Garage' started by red5033, Oct 29, 2004.
  1. red5033
    red5033 Newbie
    Oct 29, 2004
    4
    Just bought a 85 K-5. It had no lift and 33x12.50's on it and the tires rubbed when I turned the wheel fully. I just finished installing a 4" suspension lift and it clears the tires with no problems. Now Im considering going to a larger tire but dont want to be back where I started from. Will 35's rub with the 4"? Im not against some minor triming...If the 35's are out, Ive seen some 34's out there..Oh, and Its mostly a daily driver with some occasionaly light duty off road use here in Flat Florida..
    Thanks,
    Red
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    you'll need to trim a little, but if you keep the anti-sway bar on there you should be fine with 4"/35s.
    j
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    j
    [/ QUOTE ] You can also add a set of ORD Zero Rates on both the front and back for a extra inch of lift.
