Lift with no vibe??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WheelinK5, Feb 6, 2002.
  1. WheelinK5
    WheelinK5 Registered Member
    Oct 12, 2001
    55
    Vegas
    I am going 4" lift on my '85 Blazer. What needs to be done to make sure I have no vibrations I have heard about? Will I have to go slip yoke shaft? Can I get away withg a 4" and no vibe?
    Mark
    1985 K5
    Built 330HP crate 350, SM465, NP208, 10 bolts, Ranchos and 31X10.5 on Rallys!
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    when i lifted my 89 suburban 4" i didn't have to do anything but the blocks (yuck) have an angle built into em so i didn't have to. if you're doing springs in the rear you can shim them, not sure how much though. the front was fine for me. as for the drive line my slip-yoked np-241 is perfectly happy with it. no new shafts req'd.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I also had a 4" and had no vibes. Just used blocks in the back with a taper to them (don't recall how much) and everything was fine. No lengthening of the front shaft, I think I did go with a longer rear shaft after I broke the old one. When I went to 6" is when I started (and still do) having vibe problems...
    If you do have a vibe with the 4", you should be able to get some cheap shims to correct the problem...
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    If you have any vibes, try using a shim to point your pinion towards the t-case...you can also drop the t-case whcih is accomplished my taking the spacers that are in the frame rail where the crossmember is attached and placing the spacer(s) in between the frame rail and the cross member... pretty easy once you get under there and see what I mean...but with only a 4" lift, you shouldn't need to do too much...
    Chris
    Was that a speed bump? No, just a Rice Rocket </font color=red> <a target="_blank" href=http://coloradok5.com/gallery/fortcollinsram>My 87 Blazer</a>
  5. WheelinK5
    Oct 12, 2001
    55
    Vegas
    Thanks for the replies! If I go with blocks in the rear will I be OK if I don't try to pull a building with it?
    Mark
    1985 K5
  6. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Yep..... blocks will be fine ..... even small buildings can be pulled...... [​IMG]
    1990 K5 4" lift, 33's, 14FF Detroit locker, D44 w/ posi, 4.10's Raptor Tranny and Velvet Rides....
