Lift
Discussion in 'The Garage' started by tappan, Feb 14, 2006.
  1. tappan
    tappan Registered Member
    Nov 13, 2005
    15
    Denison,Tx
    I have a 1978 Blazer. Want to lift it with a 3'' lift kit springs front and back.
    Will this allow me to use 33/12.50s? Also what is a good brand at a good price and who from?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes you should be fine you can run 33's with no lift at all
  3. tappan
    Nov 13, 2005
    15
    Denison,Tx
    lift kit
    Thanks Jimmy.
    what about the lift kit?
  4. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Tuff Country is about the cheapest good quality lft kits. I am not sure if they have 3" lifts. They probably have 2", but I do not know about 3". If you really wanted 3", you could buy a 2", and then put some Zero Rates under those. A 2" lift would be plenty to fit 33" tires.
  5. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Tough Country makes 2, 3, 4" springs. BDS makes 2.5" and 4" springs. :D
    I would LOVE to have any of those heights, my either manufacturer :bow:
    thanks,
    James
  6. tappan
    Nov 13, 2005
    15
    Denison,Tx
    Thanks 1-TON
  7. tappan
    Nov 13, 2005
    15
    Denison,Tx
    Thanks 78 SUBURBUN
  8. tappan
    Nov 13, 2005
    15
    Denison,Tx
    I ment an sorry
  9. tappan
    Nov 13, 2005
    15
    Denison,Tx
    ok i want to put a 3" or 4" lift on my 78 blazer.
    been looking at tough country. I want springs front and back.
    have heard good and bad about them. hard to install,sag after a while,parts may or
    may not be quality.no off roading mainley street driven.
    please give me some suggestions on which way to go.
  10. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i have the tuff country ez ride springs and they are very good quality for the price, im very happy with them, they are soft, they dont really sag they "break in" and ride a little bit lower then they were new but they ride better. If you want some stiff ass springs that will be a true 4 inches as long as possible get some skyjackers.
  11. tappan
    Nov 13, 2005
    15
    Denison,Tx
    thanks big dawg
  12. tappan
    Nov 13, 2005
    15
    Denison,Tx
    is there any difference between rough country and tough country lift kits?
  13. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Rough country-The name says it all. I would suggest using a 4 inch Tough Country spring in front and a shackle flip in rear. The ride is smooth:D .
    Ira
  14. tappan
    Nov 13, 2005
    15
    Denison,Tx
    I am installing a 4'' lift on 78 blazer 4x4.
    the nuts on front side of rear leaf spring is partially hidden by the frame.
    Any suggestions on how to get to them?
    Any other tips on how to install would be great.
  15. sandawgk5
    Oct 28, 2003
    6,881
    Ya use an open end wrench and put an impact on the bolt and knock it off.
    Ira
  16. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    rough country are real stiff and dont sagg but dont felx much
    tough countrys are the way to go in front and shackle flip rear
    LUKE
  17. tappan
    Nov 13, 2005
    15
    Denison,Tx
    gettin ready to install 4'' lift springs front an back. stock springs are 52'' new measure 48''. will the shakles flip out enough to reach the new springs or is there a trick to bolting them up?
  18. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    try using the search button, it will answer most if not all the questions you have on the subject:waytogo:
  19. sandawgk5
    Oct 28, 2003
    6,881
    Stock rear springs are 52" long and stock fronts are 48" long. If you have 52s in front put them back in cause they flex like mad:D . Are you sure you are putting the right spring in the right location?
    Ira
  20. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    BDS is great too. The springs and components are lifetime replacement too. excludes shocks. Good heavy duty Military spring. I just ordered the Rough country6'. I should have ran it by the council first to find out more info on them, but what the hey it was not so expensive.
