lift?
Discussion in 'The Garage' started by 88-3/4t-bad boy, May 31, 2006.
  1. 88-3/4t-bad boy
    88-3/4t-bad boy 1/2 ton status
    Nov 27, 2005
    150
    Texas
    i want to know what steering components are needed for an 8" lift?
  2. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    crossover steering and a drop pitman.
    or do like i did, i have full lock to lock steering.
    2wd gearbox
    ORD's High steer
    blam pimp steering.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    If you wheel it Crossover is the only solution period.
    If you don't wheel you could do a steering arm and a dropped pitman arm.
    Wheeling is defined as trails that would require suspension movement and steering at the same time:D
    If you wheel it really hard and it doesnt see the street=Full Hydro.
  4. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    i do mild wheeling in my 1/2 ton burb but im building my dream burb over the summer. i bought a six inch lift but now that i think about it i want an 8 so im trying to find out which parts i can keep.
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Crossover is really nice just for daily driving as well. I am going to put it on my 89 Crew cab as well, but I dont whheel it. It tightens up the steering with new joints everywhere, makes it more "new carish" feeling, and it performs better than push pull steering.
  6. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Where and how do you plan to wheel? I run a 9" lift on my '85 and for mud and sand it's fun but don't expect to get much flex, just an altitude adjustment. ;)
    If you're like me and only plan on doing the dunes and some local mud then altitude is your friend but if you are thinking about trails you may want to reconsider that 8" lift.
    -Avery
