  1. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    Rough Country lift went in easy and I'm very happy w/the ride. It's about 3 weeks old. Well, got a chance today for a front end alignment. The fellow told me it doesn't turn all the way to the right. I never noticed b/4. Never had to do a right hand U-turn. It is annoying as I tried to swing into a parking space. Found that out just now at Home Depot. So, how do I correct it? A dropped pitman arm?
    Thanks.
    1972 K5
    1991 Jimmy
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Is your drag link level (parallel to the ground) if so you can adjust that to get your turns equal. What I did was went to a parking lot and drove with the wheel cranked in one direction then the other way and adjusted the drag link until the circles were the same. Make sure your steering stabilizer in centered also.
    Good luck
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I don't think anyone makes a dropped pitman arm for the Gen1. They do have raised steering arms and S-shaped drag links for our Blazers, though. Depending on how much lift you run, either the S-shaped drag link or the raised arm (or both) may be necessary. Some of the raised steering arms seem to introduce a lot of bump-steer into the suspension. A friend had one with his 4" lift setup and it was awful. Changing back to the stock steering arm and going with an S-shaped drag link greatly reduced his bump-steer.
