  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    I am thinking about getting my 87 K-5 lifted but not sure if I want to put 33's and a three inch body or put 35's with a four inch suspension lift.I would go with the four inch with 35's in a minute if I knew that 10 bolt rear would hold with those 3.73 gears what should I do yall.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    First of all, what type of wheelin do you do? If it is mild to moderate and you dont have a heavy right foot, you will be ok with the 10 bolt and 35's.... And i am not a body lift person, I stay away from them at all costs! Yuk!!
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  3. blazingboy
    Dec 2, 2001
    120
    Georgia
    most of the wheeling I do it is pretty light ,but on the street I give it the occasional to the floor but not on every traffic light I guess If I do get 35's and something goes bad I will just replace it.
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Dont worry... 10bolt isnt as bad as people put it out to be... they msotly break under conditions of small geras, huge tires, equped with weak gov-lock, and hard wheelin... my 10bolt hasnt shatered or busted... i run 4.56 gears with 35's gunna step up to 36 or 38... going to put an eaton posi in , in january. As long as you dont do anything hard core or rock crawl you will be fine.
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    In desperate need of a rebuild.
    Next- Eaton mech locker... Flows.
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Go for the 4" and 35's... it is a great look!
    If you have to change gears from what you have... get 3/4 axles and be done. It will be cheaper then a re-gear and you will have no worries. Learn from my mistake. Also if you have the 700r4 tranny (OD) then go 4.10's or 4.56's w/ 35's or 4.10's w/ 33's
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  6. 84silverK5
    84silverK5 Registered Member
    Nov 28, 2001
    65
    Hillsboro Oregon
    i sport a 10 bolt (not for too much longer) with 38"s and 3.73's and i wheel somewhat hard, it hasnt done anything yet, but down the road youll want a 3/4t rear if you step it up in the wheeling aspect
