??Lift??
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by blazerboy72, May 18, 2002.
  1. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    Do I have to have my driveshaft lenghtened for a 6" lift THANKS
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Most likely YES! Also fill out your profile so we know what you have /forums/images/icons/wink.gif
  3. blazerboy72
    Mar 29, 2002
    260
    hiram ga
    about how much does it cost?
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    dont half ass it, just get a cv driveshaft for $200-300
    NITRO
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    you dont have to get a CV...if you play with the angels most of the time you can get it to work fine without a CV shaft...but if you just dont want to mess around with it get one with a CV
  6. Racefreak
    Racefreak Registered Member
    Apr 1, 2002
    67
    San Antonio, TX
    I just installed a 4" Tuff Country front & rear spring kit from ORD a couple of weeks ago. I also put 33's on it. EVERYTHING was off! My rear shaft was 2" too short. The angle was not good either. A good friend of mine is a 20 year driveline guy, & crawled under & took measurements. He told me to do the CV, no doubdt. It wasn't the length so much, but the angle. He said I would be sorry. I took the shaft to Driveshaft Specialists here is San Antonio last week. He said I could pick up 2" with a CV, NOT having to lengthen it. This is due to the different slipyoke & joint. He also said that they would have a used slipyoke on another shaft in the scrap area, which is great. That yoke is expensive new ($60). Balanced, painted, & CV'd should run me $100-$140. Here's a little something else. My front shaft won't bolt up now either. The lift angle won't clear the exhaust in front. SO, it looks like I'll have to chain up the shaft & go get new exhaust. I was going to do this anyways. Also, ALL my brake lines are taut now & need lengthening. The parking brake line won't reach either. Apparently on a first generation, the rear Tuff Country springs are more than 4" due to the location of the hangers. It is quite a bit taller. No butt sag either, even with the top on & tires in the cargo area. GOOD LUCK!
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    if you go over 2 inches of lift everything must be lengthened.brake lines,ebrakes,and driveshafts.my stock driveshaft busted where the spline go together on the slip yoke when the axle was at full drop over a jump. im thinking of a fixed yoke cv shaft my self
  8. blazerboy72
    Mar 29, 2002
    260
    hiram ga
    thanks I was trying to decide wheteher to get a 4 6 or 8 inchlift when i ever get the money. i wont be using a cv though
