Lifted Duallies: How to fit big tires?
Discussion in 'The Garage' started by DavidB, Apr 5, 2006.
  1. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Those of you who are running big tires on duallies, what are you doing to space the tires apart? THX - David
  2. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    I have a set of these cheap Ebay $20 1/4" wide spacers on my Duallie. The tires on my duallie are only 285/85/16 (33" diameter), so they do not need a whole lot of spacing. The one in the middle are from Wheel Adapter Accessories http://www.wheeladapter.com/DuallyAdapters.asp.
  3. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    the middle ones arent designed for dually application.
  4. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    mmm dually on 44's... sorry i cant help with the tech part but here are some pics to get ya motivated to DO IT!!! :bow:
  5. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    God damn, that thing is all tire! Now if it was a crew cab that would be hella sweet.
  6. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Now...how to do the spacing...?
  7. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    I have had two duallys that were lifted and they both used performance wheel spacers like the ones pictured above with the dual bolt pattern.Both were 2 inch spacers. Enough to run 37x12.50 tires. The rim width is what limits you and overall width.
  8. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Thanks...I'll be running 11.00x16.00 Michelins..nice n skinny. Any strength problems running spacers like that?
  9. Orange Crush
    Mar 6, 2003
    440
    To hold one of those spacers in your hand you would say I would never run it. But I had a 99 superduty dually with the spacers on it and the inside tire had a cut in the side wall and it took two weeks to get a new set of tires and we drove it around the whole two weeks on just the outside tire holding air bolted to that spacer with the inside tire flat. I have towed a few thousand miles pulling my K5 or a 6500 lb. pontoon boat without a problem. I say that they are Ok for what I do with them.--Eric
  10. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    I have a machine shop...will probably make my own. Steel, and precise fit.
  11. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    now I wish I bought a dualy. Those things look bitchen lifted!
    ~Brian
  12. Orange Crush
    Mar 6, 2003
    440
    K10A'sBROinSLO , if you make some spacers Pm me I would like to talk to you about making me a set.I saw a truck like the blue one with the 44s at a truck show and that is what he did. It looked like his spacer was like 5 or 6 inches! The truck that I saw looked exactly like the blue one posted could have been the same truck. Any how if you make some Pm me--Eric
  13. Orange Crush
    Mar 6, 2003
    440
    Heres a few pics of my 91 only had it a few weeks. Need to do some clean up work to it.
  14. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    Orange Crush... That is a '91?
    I thought that the trucks changed body style in '88 and the Suburbans changed body style in '92.
    Does anyone have additional information about this?
    Oh, and I think the lifted dually look is awesome. Good flex too. Ode to long wheelbase...LOL
  15. bigbluesuburban
    Feb 8, 2006
    1,362
    Get some dually axles and build yourself a dually 89 K5 Blazer with 44's and 12" of lift. I know I would like to see it.
  16. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    i wonder if that 91 dually's rear flex is related to the width creating leverage on the springs and forcing flex. i guees the xtra unsprung weight has some effect too.
  17. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    the body style did change in trucks in 88 except for crew cabs which did not change until 92 the breakdown for the older body style is:
    73-91 blazers, suburbans
    73-87 all pickups
    88-91 crew cab pickups
  18. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
  19. The Butcher
    The Butcher 1/2 ton status Premium Member
    May 17, 2005
    429
    42
    Texas. In a van, down by the river!
    Those are CRAZY!!! Cool looking, but completely ridiculous at the same time. Look at the pic of black Chevy that shows front suspension and driveline angle. How does that driveshaft even turn coming out of the transfer case at that angle?
    I have to admit those trucks look cool as hell. I wonder how they ride?
  20. Orange Crush
    Mar 6, 2003
    440
    The front does not flex hardly any due to the swaybar. The rear is flexin pretty good but that is a lot of frame flex too. It has 6 inch springs front and rear with a 2 inch block in the back also.--Eric
