Lifter blocks, good or bad?
Discussion in 'The Garage' started by dodgetruck91, Mar 16, 2003.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    I just want to start with a 2" lift, cna i do blocks in the front and the back?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You can use blocks for the rear.
    Blocks for the front are dangerous.
    If you wanr a simple 2" lift, try a body lift. It will be the cheapest.
    -- Mike
  3. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    just my opinion, but you sound new to this, or new to suspension issues. There is no reason to use blocks in the front, springs are not theat exspensive=no exscuse. I would hate to find out a blazer and his owner died because the cheap way out.
    Companies such as bds and trail master make cheap lifts and they can be installed in a few hours and common tools.
    I have both body and spring and I think the body lift id hardewr to do, it is really basic but after you deal with things such as shift linkages or gas filler hose the suspension is the better choice.
    ask questions we are here 4 ya /forums/images/graemlins/thumb.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] NEVER use blocks in the front !!!!! It's unsafe.
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    It is my opinion that all blocks are unsafe. I guess after breaking the 2 inchers I had in the rear of my burb, at 40mph, and having the ride of my life, I get to feel that way. /forums/images/graemlins/eek.gif The carnage from that happening took a while to repair. I guess the 388, the shift kit it the TH350, and my heavy right foot were too hard on the blocks. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/eek.gif
  6. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    i ran 4" blocks in the rear of my Jimmy for a few years. IMO, if you arent going to abuse your rig too much, they are an ok way to get lift in the rear. never use them up front though.
    j
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Yes please don't be like the guy who entered top truck challenge with a front lift ath was just 4" blocks!
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    a 2 inch suspention lift is only a couple hundred bucks.they usually consist of add aleafs to get the 2 inches lift.if you want to use any kind of block i would get the zero rates offerewd by a couple of companies on this site.they bolt into the spring pack and essentialy become like an extra spring.they can be offset to help with pinion angles also.
  9. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    It's especially dangerous if you use UNTREATED lumber!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
