liftin my 91
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ok91blazer, Jul 10, 2002.
  1. ok91blazer
    ok91blazer Registered Member
    Jul 7, 2002
    42
    stillwater, ok
    i got 4 in superlift springs for the front of my 91 k5, and 4in, blocks in the rear, and was wondering would i have to lengthen my driveshafts, and how would my driveline angle be? what if i added some ord shackles? would i have to drop my t-case, and also, do i need to get a drop pittman arm?
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    a search would get you more detail but to summarize. You will need a drop pitman arm, longer brake lines, the same driveshaft can be used, and you will only need to drop the transfer case an inch if you get a vibration after lifting your blazer
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    4 inches of lift is pushing the limits of the slip yoke on the driveshaft. I had a 2.5" lift and it didn't seem to like being pulled out that far. Longer brake lines yes and a dropped pitman arm couldn't hurt. That's what i would do. As for the transfer case drop, look in the channel of the framerail where the transfer case crossmember mounts. There should be 4 bolts, each with a spacer on it. Simply unbolt it, after you support the transfer case obviously, and put the spacers in-between the crossmember and the frame. Voila, instant 1 inch transfer case drop, and it really won't affect the distance between the distributor cap and the firewall. That's my 2 cents worth of experience.
    Ash
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what does a drop pitman arm look like exactly im not sure just beggining at this..and i too will eventually be planning a 4" lift on mine...
    Bryan
  5. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i just lifted my 91 a few weeks ago.4"front springs,shackle flip and zero rate add a leaf in back(5").i got new stainless brake lines and a steering arm is a must.as for the driveshaft,put the lift in and see what happens.mine had some vibes,but i also swapped in 3/4 ton axles also which may or may not have a affect.i ordered a cv driveshaft from arizona driveline with the 1350 u-joints and the correct length.this solved all my vibration problems.good luck!
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what exactly cuases the viberation?
    Bryan
