Lifting Dually Questions
Discussion in 'The Garage' started by DuallyK5, Aug 28, 2006.
  1. DuallyK5
    DuallyK5 Registered Member
    Apr 6, 2006
    32
    New Jersey
    Im getting a 8 inch suspension lift from superlift and im going to be putting 38.5x11x16 inch rims on my dually. What size spacer should i get for the rear? I heard there was a guy with a c3500 and a dana70hd and he ran 13 inch wides duallys on stock 16 inch rims and only a 3 inch spacer and he said he could have proboly used a 2 inch. What do you think i should use.
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    lifting a 1ton some times you need to cut and clock the shock mounts on the axle. my cab chassie with 4" needed the pass side done to bolt the shock on it.
    only thing i see a problem with is the spacers dont have the correct center lip to center the rim on a dulley axle. then the outer tire might wobble a bit and be a pain in the ars to center.
    sorry i cant help anymore.
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    You might have better luck here...
    http://www.towrig.com/roadmaster-active-suspension.shtml
    It's a great site, that's just a sample article I remembered reading a while back but go check out the forums. Mostly because being a towing site (which is still connected to CK5) a ton of guys run one tons.
    -Avery
  4. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    You're right, Eric. That guy's certifiable..........
    :rotfl: :rotfl: :rotfl:
