? LIFTING FRONT 1 1/2 -2 INCHES
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1989k5, Mar 6, 2004.
  1. 1989k5
    1989k5 Registered Member
    Jun 10, 2003
    36
    near Lake Superior, Wisconsin
    I know it is late and don't expect any replys right now, but I would like some information on lifting the front of my 89k5 1-1/2 to 2 inches only. The back is up 3 1/2 inches from new 6 leaf springs and blocks. The front I am debating building blocks for or purchasing rearched springs to give the required lift. Also, do I need to lengthen or replace anything else that could be stretched to much. It seems to me, everything should flex enough with such a small lift. Please, any feedback would be appreciated. The reason for the small lift is I only want to go 33 12.50 tires since I pull a middle weight boat 20 to 100 miles for frequent fishing trips. [ QUOTE ]
    [/ QUOTE ] 1989k5 10b frnt/rear. NP241/700R4/350. 31X10.50 stock. rear 3 1/2 inch block lift. Plan 33 12.50 if front lifted.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you have stock springs? if so you may wanna try a add aleaf. it may ride a little rougher.
    or you can go with zero rates from Offroad Design which adds 1" its not what your looking for but an option
  3. cuzinjay
    cuzinjay Registered Member
    Feb 13, 2004
    62
    rome ny
    I say 2.5 springs(better ride) in the front or add a leafs(will stiffen your spring).Blocks in the front in a serious no no.The force on the front when steering can cause the blocks to fail and cause you to loose control.The blocks in the rear will be fine though.
    I don't think a 2.5 lift should bother anything didn't on my bro's 89.He ran 35"tsl's with a little /forums/images/graemlins/hack.gif
  4. 1989k5
    Jun 10, 2003
    36
    Thanks for the quick reply, I will look into these options. As you said the add a leaf can stiffen the already stiff ride, but the 1 inch zero rate may be on option. 33 12.50 tires should clear ok with a 1 inch lift since my 31's clear easily. The back is about 2 inches taller than the front. I originally lifted it to make up for the stock sag, but now it kind of resemble a shackled up chevelle I used to have. In your experience, does the zero rate add any stiffness, I'm not sure if it is a block system or what. Thanks again for the advise.
  5. 1989k5
    Jun 10, 2003
    36
    Do you know of a company that makes 2.5 front springs, or is that a common enough lift to find.
  6. BIGDAN112686
    BIGDAN112686 1/2 ton status
    Nov 20, 2002
    112
    nc
    off-road design(www.offroaddesign.com) sells tough country 2.5 inch springs. supposedly very good and i wish i would have gone with them. but definately check out that website.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's common, just not too many people go that route.
  8. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Blocks in the front are Illegel in most states and are an Accident waiting to happen. You could add some longer shackles in the front. The only problem doing that is you will have to check your pinion angle and also Caster angle.... /forums/images/graemlins/thumb.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's CASTER angle, not camber.
  10. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Yep, thats what I ment, No Coffee yet (yawn) /forums/images/graemlins/eek.gif
  11. cuzinjay
    Feb 13, 2004
    62
    rome ny
    [/ QUOTE ] In your experience, does the zero rate add any stiffness
    The zero rate is pretty much a 1" thick add a leaf that bolts to the bottom of your spring pack.It will give you 1" of lift with out changeing the way it will ride.
  12. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    here is the link to ORD's site with the zero rates. zero rate
    they are almost exactly like a add a leaf, but it covers just the perch, therfor adding no more spring rate
  13. 1989k5
    Jun 10, 2003
    36
    I'm sure glad you guys are available for advise, it sure eliminates a lot of error on my part. Lifting vehicles is not included in my area of knowledge so I'm glad I can rely on this website as a source. I'm going to take some measurements to see how little lift I can get away with to fit 33 `12.50s in and maybe the zero rate would be a good choice. My biggest problem with lifting to much is clearance into my garage approx 7ft. I tend to bump the door with the cap now. Another consideration for the 2.5 inch lift is does it add any ride quality, in other words, does it soften up the ride? I'm going to check out the recommended websites that were posted and read maybe the tech tips they have. I'll post my decision and give an update on the outcome. You guys are great, thanks for being a resource. /forums/images/graemlins/cool.gif [ QUOTE ]
    [/ QUOTE ] 89k5350700r424110bfrt/rear/ 311050.
  14. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I did zero rates about 2 months ago and I love them. They are inexpensive, very easy to install and are safe for front end use. I would go with that. They will even put like a one degree angle on them so they wont affect your driveline angle. but in my opinion 1 inch will not affect much.
  15. 1989k5
    Jun 10, 2003
    36
    I read the offroaddesign.com catalog description and like the idea of the zero rate as well. The description states that there is an offset that can be used to bring the axle fore or aft depending on where the center pin hole is drilled. Thanks for telling me about the pitch they can build into them for shaft geometry. My rear axle I struggled with for a few months to get the vibrations taken care of. I'm going to order them tomorrow and put them in on my next day off. I think that will cure what ales me. I love this truck and am so buried in it with time and money, getting advise save me both. thanks again.
  16. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I installed the zero rates on mine and moved the front axle foward 1" and the rear back 1". I love it and It doesnt make it any rougher. /forums/images/graemlins/waytogo.gif
