Lifting idea...
Discussion in 'The Garage' started by 84gmcjimmy, Jun 18, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, I have around enough money for just lifting the blazer... as it will be down for a while, I am not worrying about steering corrections/x-over steeroing yet. And I still need to find the drivetrain. Here is what I have planned:
    52" and 56" springs from ORD... zero rates in the front pushing the front 1.25 inches ahead. zero rate in the rear LIFTING the truck 1 inch (in case it sags in time) then 1 inch body lift. With the 52" springs it will give me around 4" of lift up front. And with the 56" springs, I might flip them to make 3" more wheelbase. Then get/make a shackle flip for it. So that gets me to 6 " in the back, and 5" in the rear. So I am thinking to get 2" 56 springs, and 2" 52 springs to make 8" in the rear, and 7" in the front. I am thinking out loud so hopefully this makes sense. Thanks, and input would be good /forums/images/graemlins/thumb.gif
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    NIX the lift springs and make up your own front spring hangers to even out the lift and you've got the setup I'm building. I got heavily trimmed fenders also. /forums/images/graemlins/waytogo.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    52s are more like 5" lift. I'd forget the front zero rates and run a flip and zero rates outback. You can drill the spring perches on your front axle to gain that 1.25" forward.
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    That's too complicated, get a 6" all spring lift and be done with it! /forums/images/graemlins/whistling.gif
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    So instead of zero rates in the front, I should just drill the spring perches? Thanks
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    too stiff and its no fun just to bolt everything on....
    I'll show ya my windsheild banner one day /forums/images/graemlins/waytogo.gif
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    How hard is it to drill the spring perches? Is it as easy as finding the right drill bit, marking the right spot and drilling? Or is there something I have to do before? Thanks /forums/images/graemlins/waytogo.gif
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    bump /forums/images/graemlins/grin.gif
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    eeeek, I looked at ORD's site, and noticed the 56" springs only come in 4" or 6"... see:
    REAR SPRINGS
    (52") 2",3",4",6" $350.00 pair 52" fits most 73 to 87, 56 is for higher gvw trucks
    (56") 4",6" $380.00 pair
    Now I am stuck. I could always go with the 2.5 shackle flip, then get the 4" springs, but will that still flex alright?
