lifting my truck
Discussion in 'The Garage' started by b laub, Mar 25, 2004.
  1. b laub
    b laub Registered Member
    Nov 20, 2002
    45
    illinois
    i am gonna be putting a lift kit on my 83 chevy come summer time and i was wondering what other mods besides steering will i have to do to it??
    thanx /forums/images/graemlins/truck.gif
  2. bleedchevy
    bleedchevy Registered Member
    Nov 4, 2003
    54
    Oakley, MI
    how much lift yer going with?
  3. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    may have to modify driveshafts.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Longer brake lines/brackets , lines are preffered. I recommend a steering box brace. Even with steering arm the draglink get adjusted, it WILL be off. Depending on how you lift the rear , you may need shims or a CV shaft to keep vibrations at bay. Typically 4 inches would pose no problems on driveshaft with blocks or springs and the proper shim. A shackle flip will point your rearend up higher on pinion end. You have a pickup , right? Those shafts are longer and work better lifted than Blazers shorter shaft . Let us see it when its done /forums/images/graemlins/thumb.gif
