Lifting question
Discussion in 'The Garage' started by 91k5NC, Oct 29, 2002.
  1. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    alright i found my 3" body lift last night /forums/images/graemlins/grin.gif, im going to put a 4" suspention on it here soon just wondering if it is a good idea, and if 33's would look right or not. i don't think it would look right with 7" of lift and 33's. thanks.
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    7" of lift with 33's would not look right. It would look like a truck with 20" lift with 44" tires, not /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
    Just do the 4" if you want to run the 33" tires.
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. 91k5NC
    Jul 12, 2002
    206
    Durham Nc
    what size tire can i run with that and it look right. will the body lift mess any thing up when im doing mad! flexing.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you put the 4in spring lift in and the 3in body lift you could fit a set of 36's under it /forums/images/graemlins/smile.gif
  5. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    I guess you are not wanting to do any fender trimming? If not with 7" lift you could run a 38" tire easy with a 8" wide rim, but if you went 10" wide rim you would probalby rub off road if you twisted up real good. Depends on what type of wheeling you are going to do.
    Also if you go above a 35" tire your stock gearing and axles are going to suffer quite a bit aswell. This /forums/images/graemlins/k5.gif building always has the domino effect /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  6. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    You're going to move a lot of stuff out of alignment with a 3" body lift. Do the suspension first, then decide. /forums/images/graemlins/rolleyes.gif
  7. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    I had 33" on my stock K5, then put a 4" susp. on it.
    I think it looks OK, but 35's and a little fender triming
    would be better. My sugestion would be, don't do body lift. Do nothing but suspension. Better in the long run
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  8. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i got a 4" and 33's and they look small. im goin 4" and 35's (if i ever get $) so i say do 4" suspension w/ 33's and go from there
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I run 4" susp + 3" body with 38x16 swampers and a lot of fender trimming. The 3.5 offset of the rim didn't help with the trimming but it doesnt rub.
    Had 4" and 33's - front always rubbed with 8" rims on stock axles and rancho springs.
    Heres the 38's and the trimming:
