Lifting the burb
Discussion in 'The Garage' started by cbbr, Dec 1, 2004.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Installing ORD shackle flip. The sparks from the grinder look great bouncing off of the gas tank. Safety first. /forums/images/graemlins/grind.gif
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    don't forget to take plenty of pictures and good luck /forums/images/graemlins/waytogo.gif
  3. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    If your worried, fill up the gas tank. Gassoline fumes explode, but gas as a liquid just burns... /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
  4. cbbr
    Jul 17, 2004
    14,681
    After much confusion(first time /forums/images/graemlins/thinking.gif), 3 parts runs (if it don't fit,cut it off and get a new one, right? /forums/images/graemlins/grind.gif)and 1 beer run (no excuse for this poor planning)the rear is done. ORD flip and zero rates for 5" and 35" BFG's. Many pics.The front will be done on Friday, although it looks good now in that redneck kind of way. /forums/images/graemlins/pimp1.gif
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    gasoline does not burn, it is only flamable in a vapor form. dont believe it? throw a lit cigarette into a can of gas, it just goes out.
  6. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Ummmmmm no..........the fumes coming off the gas will burn....and the heat from the flame will only make the gas evaporate faster creating more fumes.... If it were really cold, you could throw a match in and it wouldn't burn because there would be next to no fumes but if its warm its not something that I would want to be doing without a little distance.
  7. cbbr
    Jul 17, 2004
    14,681
    That's an old trick that I have heard from military guys used to scare the FNG. Of course, the military was using diesel at the time, so I'm not sure that I would try it with gas. /forums/images/graemlins/weld.gif
  8. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    It actually works with gasoline too. I knew a guy that use to scare people (me included) with that trick. He hasn´t blown himself up yet /forums/images/graemlins/ooo.gif
  9. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    And... this is different from what I said... how? /forums/images/graemlins/ears.gif
    You can get say a can of gas to burn, you have to get it warmed up enough to give off fumes... just like alcohol (which is actually pretty tuff w/ a cup of it). So true, the fumes burn but a fume filled room will explode, while you can get a can/puddle to burn as it boils the gass below....
  10. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    just a little fun fact.
    gas fumes at 14% airmixture are AS explosive by volume as TNT.
    trust me i have blown lots of stuff up. /forums/images/graemlins/tongue.gif
  11. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    [/And... this is different from what I said... how?
    You can get say a can of gas to burn, you have to get it warmed up enough to give off fumes... just like alcohol (which is actually pretty tuff w/ a cup of it). So true, the fumes burn but a fume filled room will explode, while you can get a can/puddle to burn as it boils the gass belowquote] so a full tank of fuel is much less likely to explode than a tank 1/4 full? /forums/images/graemlins/dunno.gif
