lifting the front end
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Oct 21, 2002.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    ok i currently have an 8 inch superlift and i want about 1-2 more inches of lift, i cant go body lift cause the rollcage is welded to the frame. i saw a blazer in fourwheeler that was running extended shackles on the rear shackles of the front springs. Is that really worth it or should i go w/ zero rates(wat are those?)
    thanks,
    phill
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    What's the price on a new lift ??? Say like a 12". Then you could sell the 8" lift you have too try to make some money back.
  3. shupach
    Dec 28, 2000
    648
    Dallas, TX
    i dont wanna sell my lift, already have the biggest pita sellin my current parts, dont wanna add stuff to that list
    phill
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'll be installing a custom block for the front. I will remove the rivets that hold the front end bracket that holds the spring and install a 4" metal block in there and bolt it with grade 8 bolts.
    Anyone see any downside on doing this? It should do a similar effect to the shackle flip on the rear axle, pointing the pinion upwards.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Lowering just one end of the spring will rotate the axle housing, totally screwing up your front end alignment. Lowering the rear of the spring will also rotate the pinion gear down, making the driveshaft angle worse. Lowering the front of the spring will bring the caster angle back towards zero, which can cause a very bad case of the dreaded death wobble. /forums/images/graemlins/shocked.gif
    Perhaps slightly longer shackles and lowering the front mount could get you where you want to be, without messing up any of the angles.
  6. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    What about adding Zero-rates and ORD ro Hill Shackes /forums/images/graemlins/wink.gif That should give you 1.5-2 inches /forums/images/graemlins/thumb.gif
  7. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ok wat are zero rates, where do i get them, how much do they cost, how hard are they to instal. and yes i was gonna go w/ a small shackle flip in the rear so i could get bout 2 more inches.
    phill
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Look on the ORD site. They are $40 for a set.
  9. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    Zero rates are very easy to install, just take off the ubolts on the axles, clamp the spings, and remove the spring pin. Bolt the new spring pin with zero rates and yer good to go /forums/images/graemlins/pimp1.gif
