Lifting?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TrailBlazinK5, Feb 10, 2003.
  1. TrailBlazinK5
    TrailBlazinK5 Registered Member
    Jan 13, 2003
    38
    Kansas
    wanting to do a 4 inch lift on my blazer and want to know if i need to extend my driveshaft or will the stock work fine??
    Also another? as anyone ever made a different crossmember for there xcase to get a little more clearance?
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Depends on what you use the truck for. The stocker will work to get you around, but will pull apart or fall out of the tcase (depending on year) if you do much with it. Go get it lengthened, it'll cost you 50 bucks.
    Check here.
  3. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I got a burban with a 4" suspension lift and I am sure the front driveshafts are the same lengths. You dont have to extend it, though the slip joint will wear out quickly and become loose. I have replaced mine twice. Now I can grab in the center and shake up and down, I am a little self concious about that. When I get the money I will extend it. /forums/images/graemlins/usaflag.gif
  4. TrailBlazinK5
    Jan 13, 2003
    38
    Kansas
    thanks for the info i figured i would have to lengthing the driveshaft...
    thanks again
    bill
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Truthfully, a lot of people do a lift like this and use the stock length driveshafts with no problems. I have about 5" in my suspension and I still use the stock driveshafts. However, I do have a 14B rear and the longer pinion put my slip yoke about back to where it was stock.
    A lot of it depends on how much suspension travel you are going to see.
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Depends on the truck. Every rig is different. I had to get a new rear shaft just for a 3" lift. /forums/images/graemlins/rolleyes.gif
  7. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    yea truthfully that is one thing that is scareing me about doing a 4" suspension lift, is that driveshaft thing, i dont know if mine is long enough, i got a 87 shortbed pickup 4x4 sm465\np208 combo, and the 10 bolt up front and a 12 bolt axle out back, and im going R\C and those are stiff, im just crossing my fingers. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Having new driveshafts made is no big deal. I had to have both shafts made when I put in my 6" lift. Just like every mod, it only takes $$$$$$$$
  9. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    that is what i dont want to do is spend the $$$$$$$ on a driveshaft /forums/images/graemlins/crazy.gif.
