Liftting Newbie
Discussion in 'The Garage' started by BronzeAccord, Nov 11, 2006.
  1. BronzeAccord
    BronzeAccord Newbie
    Aug 18, 2006
    3
    San Diego
    Hey all,
    Ive got a 85 Suburban Diesel 4x4, immaculate condition (im from SoCal). Ive got a question about lifting it. Most 4-6 inch lift kits seemto run anywhere between 400-700 bucks, fo a basic system that is. Most of them come with an OPTION of adding the rear leaf springs, and some come with just rear blocks. My question is what are the benefits of using the rear spring as opposed to using a rear block which is obviously cheaper. Im from SoCal and dont plan on doing any major off-roading, just go on snowboarding trips and whatnot. Maybe go off th trail if i need to, but nothing like you good ole boys seem to be into.
    Thanx.
  2. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    For what you want to do, I'd say go with the lift block.
  3. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    springs will give you a better ride. if you go with a 6" lift your going to need new longer brake lines, transfer case drop, and a steering arm.
  4. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    to original poster: i think that for what you're going to use the truck for, blocks would be fine. but, there is a better chance for saggy butt* with blocks.
    what size tires are you planning on running? what made you choose a 6" lift over another height (4" or 8")?
    *saggy butt is when the rear of the truck sits lower than the front of the truck.
    hope this helps. :wink1:
  5. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    In your case blocks would probably be ok, but if you want to be on the safe side you should go with new springs. Actually what i spent today doing was replacing my old blocks with new springs after almost losing a block when it cracked into peices.
  6. DirtyJim
    May 4, 2005
    665
    San Diego
    that happened to a kid in my town with a 4" lift. both blocks shattered on him while he was driving down the road. he really beat on that truck.
  7. BronzeAccord
    BronzeAccord Newbie
    Aug 18, 2006
    3
    San Diego
    thanx for the replies
    You know a couple people told me i would need the longer brake lines and all that and some people told me a i wouldnt but ill take it from you guys. So i should get the rear springs, and i should go with like a 4 inch lift to avoid all the extra stuff then?? i currently have 33 inch tires on my truck...
  8. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    well. for your case i would say go with a smaller lift and a body lift to keep it cheap... but your a lucky dog and have a diesel... so the body lift is out of the question as they do not seem to make one for your sub. it depends on what size tire you want. i mean 35's fit on a 4" lift. since your going to just be on the road. 6" i wouldnt recommend for your case. mine ended up costing a bundle. then i put it all together only to find that the front driveshaft wasnt long enough. so drop and extra couple of hundred dollars for that. even though they say all you need to do is grind the ears... well i grinded the ears... but that doesnt give you the 2" mine is off by. lol. 4" would be good. hell you trim the fenders a little bit and you could probably fit some 36's under the burb.
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    For ease of install I suggest going with a 4" lift kit. I also recommend getting rear springs instead of blocks. It will ride better with new springs. Your springs and bushings are prolly pretty wore out anyhow so you might as well replace them. Your 33" tires will look good with a 4" lift but will look real small under a 6" lift.
