light bars for rain gutter trucks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dodgedude99, Dec 17, 2003.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    who still makes them?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Here is the only place I ever see them anymore /forums/images/graemlins/thumb.gif
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Strangely enough, I have one I got in a trade and I'll never use it. Too bad your not closer...
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I'm pretty sure Pep Boys still sells them. I saw one the last time I was in there, but that was quite a while ago.
    Baddog,
    Are you interested in parting with your light bar? If so, what would you take either $$$ wise, or in trade. I only have a couple of things you might be interested in for a trade. But I might have access to something that you might need.
    Rick
  5. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    What do u want for your lightbar? I have a buddy thats gonna b in Phoenix soon maybe he can pick it up.
    lmk
    Nick
  6. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    pepgirls by my doesnt carry them anymore, i know they used to have the Rally brand.
    i was looking thru the Westin catalog they had there, a f350 they had in it had a light bar on it, but no mention of it in the catalog.
    someone has a Cepek light bar on ebay, but its only 49" wide.
  7. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    How/where do you run the wires inside the cab for the lights?
  8. unick
    Aug 16, 2003
    4,286
    I emailed him and he also has a 57" one.
    Nick
  9. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Mine was made by KC...AFAIK they still make them. Got it at a Yankee Custom Cap, but I think they're only in New England /forums/images/graemlins/thinking.gif
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I drilled a hole into the cab near the dome light and ran the wire under the headliner , rear door panel, under the carpet, and up to the switch. The cheap light kit I bought at Autozone did not have a relay, just goes to fusebox. I used a grommet and some silicone to seal the hole. But I am going to get a brushguard and move lights to my bumper asap and run a relay kit for power. /forums/images/graemlins/k5.gif
  11. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Damn I dont have the balls to drill a hole into the cab. I need an alternate method.
  12. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Don't know if this will work, but on my Burb I ran the wiring for my rear lights just through the weatherstripping in the door. You can see the wiring loom laying on the truck just above the door, but it's not to ugly and it allows me to change it later without a hole to fix. I'm thinking you may be able to run the wiring between the cap and the cab roof the same way. If you stick some clear RTV in the gap at the same time it should seal up rather well and it avoids the drilling.
    Just an idea.
  13. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    dodgedude you have a pm. /forums/images/graemlins/thumb.gif
  14. sharkman726
    sharkman726 Registered Member
    Apr 20, 2003
    22
    VA.
    I know Carr makes a light bar that holds 5 no drilling.
  15. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Yep, Carr does make them for 73-87 K5's. Found a link HERE for a CARR light bar, either black or chrone/stainless for $74.90
  16. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Dont drill into the cab. Move back a little and Drill into the fiberglass top. Then use a waterproof electrical fitting to thread into the fiberglass, (its abouta 1/4 inch thick). This way if you ever need to fill it back in you just but some fiberglass bondo in there and wala your back like new,l and no chanch for rust or leaking.
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It didn't take balls to drill hole, just figured with the amount of rain phoenix gets I'd be okay. Besides trucks are meant to be used. And after I move the lights to the bumper perhaps I could use the hole for an xm antenna or something.
  18. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    West Marine (and other boating stores) sell waterproof electrical connections. My boat gets more water over the roof than your truck would ever get, and it doesn't leak.
    Hull connector
