LIGHT BARS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wsudu, Nov 23, 2000.
  1. wsudu
    wsudu Registered Member
    Jun 30, 2000
    43
    Wichita, Kansas
    Where the hell is the best place to put the power cable to your light bars so is doesn't look like you are driving a ghetto Blazer?....Drill? Help me.... Thanks
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    It's not a hard thing to do just go through the roof. I have the wiring for mine going through the fiberglass top, about 2 inches away from the join between the roof and the top. Went along the headliner, across the top of the d-door,down along the front window and into the dash/firewall
    Then I got some spiral wire covering that you wrap around the wires, and blacked out the wires between the headlights and to the hole in the roof. Use silicon and a short ground-strap.
    Good luck!
    http://www.espen88k5.coloradok5.com
  3. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
