Light sheat metal welding anyone use mig .020?
Discussion in 'The Body Shop' started by BowtieBlazer, Jan 19, 2005.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Buddy of mine told me that .020 is down right awesome for light metal welding and patch. Anyone use this add on to their mig?
  2. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    no, but if 025 is good, then the 020 should be even better.
    i rarely have problems with burn thru with that, so the 020 would make it non existant.
  3. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    The .020 should work well. If you drill a hole near the edge of your top piece of sheetmetal and weld inside the hole edges, you can even go up to .030 without burn through. Using a hole instead of trying to weld the edge of the sheetmetal means more metal around your weld and thus more heat resistance to your work. Just something I've learned through trial and error.... Good luck.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Explain this in more detail if you can. I can't picture what your talking about :crazy:
  5. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    plug welding.
    a hole is punched or drilled thru 1 piece, then the 2 are clamp together, and you weld the 2nd piece to the 1st thru the whole.
    i was shaving door handles and such, thats why i was burning thru.
  6. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    poor man's spotweld :D
  7. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Exactly :D
