Light troubles
Discussion in 'The Garage' started by gtasteel, Mar 12, 2005.
  1. gtasteel
    gtasteel Registered Member
    Oct 18, 2004
    12
    Kaneohe, Hawaii
    Ok some one please help me out before I smash my mulit-meter with a pipe wrench... :mad:
    Here's what I got. Passanger break light don't work. But the trun signal works. If I trun on the parking lights or the head lights it lights up. If I put on the 4 ways it kinda does what it should but it's dimmer than the other side. It also blinks opposite ot eh drivers side. WTF!? :confused:
    Can some one help me out? If the answere is so stupid that it makes me look like a moron, I'm good with that!:)
    Thanks in advance...
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Usually when my truck does goofy stuff like this I check all the grounds.
  3. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    I'd put money on a bad ground wire also
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I'd go with a new turn signal switch. My parking lights would come on when I hit the brakes, both rears would flash for a right turn, and left turn would stop flashing when I hit the brakes. Replaced the switch in the column, everything went back to normal.
  5. gtasteel
    Oct 18, 2004
    12
    Kaneohe, Hawaii
    Any nice to know things or words of wisdom on that little project?
    I'll check the grounds, first, again....
    Anyother ideas, Anyone?:confused:
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Actually yes, scribe your steering wheel before you take it off (if you decide to replace the switch) so you can get it back in the right spot. The brakes and turn signals are all integrated through that switch, so when it goes strange things can happen. I don't remember where I bought it, but I eventually found it for about $29. www.americanclassic.com has it for $38 if you can't find it elsewhere. It's not hard to install, just take your time and remember where all the pieces go. A steering wheel puller makes it a lot easier too.
  7. gtasteel
    Oct 18, 2004
    12
    Kaneohe, Hawaii
    Well I changed out the trun signal switch and things are all working just fine now. Well the horn is still pretty hit and miss... Once I get the safety inspection done, I'll probably just disable it alltogether....
    Anyways, thanks for the help! :D
  8. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Good to hear, hope you found a good deal.
  9. gtasteel
    Oct 18, 2004
    12
    Kaneohe, Hawaii
    It cost about $50. It would have cost the same or more to buy it on line and get it shipped here to Hawaii. That, and I didn't have to wait for it. That's what I get for living here I guess....
    Thanks again:grin:
