Light Wireing Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, May 10, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    I have 2 kc lights upfront on my blazer, and i have a light bar, but havent gotten around to wireing the light bar. i was owndering if i could splice the wires together from the lightbar into the switch from the 2 kc lights upfront, and have 1 switch controll all
    or do i have to wire them completely seperate.
    thanks guys
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I would wire them completely seperate/in pairs. That's alot of amperage to put all on one switch.
    I have voluntarily axed "Pancho" in a bandwidth conservation effort [​IMG]
  3. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Having been an Industrial Control Electrician for 32 years, designed & installed custom wire harness' for every truck I've built, I can say with a level of knowledge that putting that many lights on 1 switch will cause you grief sooner or later. Use 2 switches and run the lights thru a relay. If you tie one relay to your high beams wiring, you'll be able to turn them off with your dimmer switch or headlight switch. If you need more info, send me an email and I'll give you more details and a schematic of the wiring. Build it right the first time and you'll never regret it later.
    Build it Bulletproof and take it fishing!
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Confederate, Check out this site: http://lighting.mbz.org/tech/ I think it will probably give you some good guidelines - follow the relay example for stock lights?
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Clickable <A target="_blank" HREF=http://lighting.mbz.org/tech>http://lighting.mbz.org/tech</A>
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Thanks Pugsley - Have you seen that site? I am thinking I pulled it from here but don't remember where....
    This place is like a library.
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've ordered oddball bulbs from them before - I think I remember seeing a reference to it here before also.
