Lightened stock hood?
Discussion in 'The Garage' started by K5 rockcrawler, Oct 11, 2006.
  1. K5 rockcrawler
    K5 rockcrawler Registered Member
    Apr 2, 2006
    47
    north dakota
    I need to know if anyone has lightened up their stock hood and how they did it. I did a search and can't find any info. I bought a fiberglass light weight hood with the step down in the middle, but it hits on the firewall and the radiator support. It just wont work. I was going to have that pinned and lift it off. Now I am looking for other ideas.
  2. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    Sorry to hear that your hood didn't work. What company is it from? Are you saying it had supports across the hood that hit the firewall and radiator support? Is it a cowl hood?
    I'm not sure that there is anything you can do about lightening your stock hood. Do you know how much it weighs?
  3. K5 rockcrawler
    Apr 2, 2006
    47
    north dakota
    The hood is from US Body. The hood has reinforcing strips at the front and back of the hood. I could have lived with the radiator support hitting as I would just cut it down. But the firewall hitting was another matter.
  4. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    What do you mean it hits on the firewall? When you put the hood up do the corners hit? Can't you shim it?
    And how is it hitting the rad support? Do you have the knob thingies there?
    Dont really undertsand your problem, can you get some pics?
  5. Smokin'Joe
    Smokin'Joe Registered Member
    Jul 27, 2006
    50
    Butler,Pa
    You could cut out some of the bracing from the underside, leaving the visable skin. This could take off a noticeable amount of wieght. Problem is you take away strength, as it would become very flimsy if you take too much bracing away. Just a thought.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    he cant take anything out. the hood is glass, and needs every bit of the support it has.
    if notching the core support isnt a big deal, why is notching the cowl? personally i'd notch the cowl before i even considered the core support. :dunno:
  7. K5 rockcrawler
    Apr 2, 2006
    47
    north dakota
    Here are some pictures for you to look at. As you can see, the hood needs to come down quite a bit. I would have to seriously mod the upper firewall.
  8. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    dont know about your hood but my god that truck is beautiful.:bow: I wish mine was still that straight.
  9. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Why not just mod the glass hood?
    Glass work is relatively easy.... Cutoff wheel or sawzall out the bad sections and mod to fit...
  10. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I think that is the same hood one of the writers for fourwheeler or petersen's used on his blazer a year or two ago. The one they tried to get the 6.0 into. I can't remeber what model it was though.
  11. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    That is a nice looking truck!!! Also the cut fenders look really clean too!!
  12. K5 rockcrawler
    Apr 2, 2006
    47
    north dakota
    Maybe I will try to mod the hood and see if that works. It is no use to me now so if I do screw it up, I always have the stock hood to fall back on. I don't know how they could build this hood and be that far off on it fitting correctly. Must have been built on a monday.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    dont mod the hood. mod the firewall. there is absolutely nothing under there, just a big empty space. remove your wiper arms and the cowl cover and you'll see what i'm talking about. if you mod that hood, you may as well lay newspaper over the engine, US Body hoods are flimsy to begin with dont need to make it any worse.
  14. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    I agree with beeter ... mod the firewall.. just pull off the hood and fenders. get a BFH and maybe a torch and just beat the edge of the firewall in and down...
  15. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I'm really interested in how this works out. That hood is in my future. Well it was...I'm assuming you've called them and asked about it? I'd definitely make contact with them before dinking around with either truck or hood. No point of screwing anything if there was a mistake in the mold or something. Please let us know how it works out.
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    why pull the fenders? :confused: his problem is obviously with the drop down section of the hood. you can clearly see a gap between the "stock" portion of the hood and the top of the cowl.
  17. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    good luck in getting them to do anything about it... :rolleyes:
  18. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Somebody here has one. That's where I first saw it. Anyone know who so they can help out?
  19. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Might be flimsy if you did the glasswork.... :p:
  20. K5 rockcrawler
    Apr 2, 2006
    47
    north dakota
    If you look the way the hood is built, I think I could cut the raised part off and move it back on the front part of the hood and forward on the rear of the hood. Then I could just glass it back in and it should'nt affect the strength alot. It would be nice to know if anyone else has had these same problems with this hood or if I am just lucky. I can try to contact US Body but the problem is I bought this hood a couple years ago and I am just getting around to putting it on.
